Page 28 of 34 FirstFirst ... 182627282930 ... LastLast
Results 271 to 280 of 336
Thread: Let the tinkering get serious!!....
  1. #271
    Oct 2010
    I haven't seen an explanation of this high flow DPF. How do you plan on it working?
    Golf GT Sport TDI
  2. #272
    if only you lived in Melb mate, I could TIG that up for you
  3. #273
    Gosford Central Coast NSW
    what are you going to do with that cone?
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  4. #274
    Jun 2011
    Isn't it obvious?
    Put it on his head.
  5. #275
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by jazd View Post
    Experimental core, improved cannister outlet flow, get Gav to do the DPF delete tune ( and then some ), but with a non clogging DPF in place that doesn't need regen yet pulls much of the soot. All theory until proven.
  6. #276
    Jan 2008
    Sunshine Coast
    OK, after several test tankfulls, I'm convinced these really work, car just seems to be that bit more "peppy". I'm still as yet to put one in a clear container of diesel to actually ENSURE they actually totally dissolve, but after a tank with just Moreys smoke killer, then topping up with Moreys and three moth balls, the car was just that bit too powerful today.....hmmmmm.
    Anything that raises octane is supposed to lower cetane, but man, it does indeed "feel" like it works....
    I have read more than 5 balls per 50L can burn the oil off your bore during combustion, but that is probably with petrol, still I am sticking to three a tank, which is what comes out of the plastic hangers these come in. Be SURE you get the 990g/Kg ones, not the new alternate chemical ones, as it is the Napthalene you are after.
    As always try at your own risk, and if your TDI blows up because you copied me, well you're a goose.
  7. #277
    if theres moths in your fuel tank you're not driving your car enough.
    '99 A4 Quattro 1.8T
  9. #279
    Jun 2009
    Dear lord Greg, the lengths you go to in search of a tinker/power boost.
    I honestly would be too scared to have tried that in my own car, kudos to you for having the guts to give things a go.
  10. #280
    Oct 2010
    Quote Originally Posted by Greg Roles View Post
    Can you give some details of what this experimental core is? Is it going to have open ended tubes in it rather than the closed end ceramic tubes in the factory one?
    Golf GT Sport TDI
