Current:12 Golf GTD, Mods on order -Bluefin Remap, Mods planned-plenty
Former:08 GT Sport TDI DSG Bluefin, HPA SHS Coilovers,H&R Swaybars with Whiteline Adj Links
Russ
2005 Subaru Outback 3.0 R Premium
All sounds great Greg.
I have to say I've always been a bit skeptical of too tight a bush when it comes to shift linkages, as too tight a bush can lead to premature wear in the gearbox if everything is not adjusted "just so". If theres more room for slop, the likelyhood of pressure being applied to the shift forks whilst cruising is lessened.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Russ
I don't drive with my hand on the stick!
It is not about the wearing in the bush or if you drive with your hand on the gear stick or not. gldgti meant wearing inside the gearbox. There is no filter to catch metal particles and 2L of oil that is there for a long/or lifetime, so in long run it is important, that there are minimum metal filings or wear debris.
But hey, maybe you have just the right clearance there and everything will be fine.
Nice to see that gldgti and Transporter have kept the thread on topic. In response to Greg's comment on not driving with his hand on the stick, I was just going to suggest that due to the tightness of your new bush it may be necessary in the future to keep your hand on the shaft due to the eventual wear that the bush will get from all the hard slamming. This depends on the whether he just puts up with the sloppiness around the shaft caused by the eventual wear in the bush or if he'd prefer to replace it with another tighter fitting bush. I believe it's not uncommon for some men to actually discard bushes (worn or not) and replace them with new tighter fitting imported ones. Each to his own I say
Now get your hand off the shaft for a while and get on with the serious tinkering already...............
Russ
