Originally Posted by
cogdoc
So I've got a 2.75 dump, and a stock 2.5 system. Given larger cat back exhausts never liberate much power ( if any! ), as the gas has cooled, and it's the hotter downpipe flow that matters, I'm thinking of sticking to the stock cat back, adding a custom resonator only, and dumping it to the road at the rear axle area. Shorter, and basically straight, should flow ideally.
Still keen on one of those Aero muffs, but they recommend putting it up as close to the front as possible in a diesel, given the lower temp gases, so I'm stuck between choosing a 3" to be as low a restriction as possible with a 2.75" pipe in, or simply a 2.5" unit. They are absolutely straight through, but all the research I've done shows they are both living up to the hype of helping flow, hp and MPG, and quieter than anyone would believe. I'm going to commit to an exhaust plan this week, so any ideas otherwise????
