Page 21 of 23 FirstFirst ... 111920212223 LastLast
Results 201 to 210 of 230
Thread: Let the tinkering begin...
  1. #201
    Jan 2009
    brisneyland
    Quote Originally Posted by Mischa View Post
    watching and waiting thanks for doing all the research and hard work greg. modded gt tdi's ftw.
    Same! Cheers Cogdoc, would love to check out your car in person at a meet sometime.
    "One art please!" --->http://benno.redbubble.com
  2. #202
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by benno View Post
    Thanks guys, but it's not very exciting as yet, just a few extra holes and wires here and there. Next step is the water spray, then I'm into replacing the inlet plumbing, from the pod back. Now that am no longer thinking water intercooler this becomes a much simpler task.
    I'm stuck with the stock MAF for now though, till I can get a custom tune for a 3" pipe. If I plug it into a larger inlet, more air will be flowing that it realises and it will be out.
    Scan gauge looks flash polar, and a LOT more simple, but I can get these stock readings from VAG Com, and you're stuck to the standard sensor position. for instance there is no temp sensor between the turbo and the cooler, so you can't really test the intercooler directly. As much as a hassle as it is, I like to be able to put the probes exactly where they need to be. Oh yeah why the heck is your speedo in MPH polar, or are they pics from the net??
    Next test will be the EGR addition!
  3. #203
    Jan 2008
    Sunshine Coast
    Logged my EGT's up the same little twisty range today with Vag Com. Saw 821 deg max at 4200 ish RPM floored. That's a whopping 1500 deg F when my diesel tuning book recommends 1200-1300 F is "about the limit". WOAH! Much to investigate, and I haven't even tried a 4500rpm all out max effort! I'm assuming though, that this is the probe just above the DPF, which is AFTER the turbine. As far as I know there is no exhaust manifold sensor, and if this is the case the impeller wheel is seeing even higher temps. Problem with Vag Com is its a guess as to what you are actually measuring half the time.... my aftermarket EGT probe, to be welded in shortly will confirm.
    Sits at about 150 at idle, almost 100 when coasting on a "closed throttle", so the diesel is indeed cool!
    If someone can tell me how to link / paste up an excel graph, I made a nice plot of the run. Going to have much fun with Vag Com now I've learnt the logging function......and Gregoz and co can wet their panties with the data!
  4. #204
    Gosford Central Coast NSW
    Quote Originally Posted by cogdoc View Post
    wow - you really need to get an egt probe into the manifold if possible.... i'm sure you'll see a significant difference. needless to say, i'm also sure your thing is hauling like a big rig. must be fun
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  5. #205
    Jan 2008
    Sunshine Coast
    OK I've started a data thread where I'll log all my Vag com data in coming weeks, and don't fret Aydan I now have an aftermarket EGT compression fitting for the probe ready to weld in. It won't be going in the cast irom log manifold though, much easier to weld in right after the turbine outlet.
    Some things even I'm scared to drill holes in, plus my gauge tops out at 1800F...
  6. #206
    Nov 2005
    newcastle
    Try "print screen", paste in paint, crop it, and save as a jpeg.
    Looking forward to some interesting numbers.
    Great work.
    Mike
    TDI mk1 on the road!!
  7. #207
    Jan 2008
    Sunshine Coast
    Thanks Mike, I googled it last night, as I had no idea what Mikinoz was on about!
  8. #208
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by POLARBEAR666 View Post
    You should buy a scangauge 2 so that you can monitor all the ECU outputs. You would already be able to monitor intercooler efficiency if you had one without your probe setup hehe.
    I just cant plug this device enough. With the setting on GTI blue it matches your dash lights perfectly too!
    My laptop matches my chunky temp meter, which is nicely offset by my half finished dynamat stereo install. I must say my girlie is loving my tinkering, she's a HUGE fan right now.
    "Just pull the wire honey, that opens the door."
    "No harder"
  9. #209
    Jan 2008
    Melbun
    get some gti seats in that badboy
    2x Caddy, 1x Ducato
  10. #210
    Jan 2009
    brisneyland
    Hey Greg and anyone else reading - do you think it's feasible to reroute the factory external temp sensor - the one that displays on the MFD - to indicate other things? I'm thinking intercooler temperature, in conjunction with a waterspray kit...
