OK back to the tinkering!
I did another read of the 125kw tech bulletin, and noticed that if the EGR throttle flap and valve units lose voltage, they just go to default positions.
The throttle flap goes to full open, and thus doesn't restrict incoming air. I liked the sound of that! The EGR inlet valve at the same point simply stays shut, and you get no exhaust gas recycled. Again, sounds good to me, performance wise. I realise it will raise the NO emissions, and exhaust temps a bit, but I figure if you decided to ditch the EGR in this manner, a chip would make the car run more efficiently, and the net increase in emissions would probably be minor ( happy hippies?
Seriously, I'm after power, but not at the expense of the lower emission footprint I am now driving!
So I unplugged them both, and drove to work.
First up, you get the error codes, and the flashing glow plug and engine light. Easy to ignore, how much better did it run?
It drove like the winter button was on. Not AS lethargic, bit a noticable drop in performance. I figured the flap somehow works in with the fuel map at lower revs, and perhaps it was now running lean, as perhaps this flap does indeed act more like a petrol throttle. Weird. Anyhow, I pulled over and plugged the throttle flap back in, and she was back to normal. I'm leaving the EGR valve unplugged for now to see what happens. Theoretically I'm now getting a better charge with no exhaust included, and hopefully more stick. EGR's will go up, but I can't see why it would be any more than a chipped car. I need to find an XR6 or S pack to race. EDIT, the EGR flap defaults to not running the cooler, but hot, uncooled exhaust still passes. The flap just lets hot exhaust enter till the water temp goes over 35 degrees, then it switches over so the exhaust goes through the cooler. This aids warmup.
What WAS interesting is that with both unplugged the car had a much more diesel like vibration on shutdown. Still as quick to stop, but a noticable rattle and vibration. I know the throttle flap shuts off at shutdown to stop any run-on. BUT when I plugged the flap back in, and stopped just now, it's still the same!
Weird!
Wonder what else you can unplug......
