Just for quick comparison I have put these side by side;
Hay was just a suggestive suggestiondoes that even make sense
LOL
Cheers,
Jamie
I'm lost as to who the heck Larry is, but yeah, I've read the TDI with no mufflers is quite acceptable. I believe the first muffler around the axle area is a resonator, which is a good idea really....
I will start with the pancake, as it should help 0-100 times with the weight loss alone!
Good work Mik, and remember you were the pioneer here! I still want your battery box.....
Sorry mate thought you guys had met. Larry's car always looks great, but you expect that from someone who has his own detailing business![]()
Cheers,
Jamie
Oh yeah and guys, if you plan to refit the top shroud over the motor, there will be a little modding required. The larger diameter Modshack housing I used fouls with the lower passenger side of the shroud. Could pretty easily work around it, but I'm not into heat retention for the sake of a pretty engine top.
Just thought I'd let you "pretty engine" types know![]()
Hi Kerry,
Oil change is easy. This is the oil filter housing. You need a 32 mm socket from your local car shop to get it off. It's hard plastic, but be careful as you could wreck the nut getting too carried away with it.
Inside is a removable filter unit you can purchase from any VW service dept for about $18. It's a simple swap, and if you're really keen, prewet the new filter with some oil, so on the first start it gets oil flow quicker.
Drain the oil after a drive, wait a good hour or two for it to cool, as you'll remove a lot more dirt than cold. JAck it up to get to the bolt, but once draining, put it back flat to get it all out. Same when you fill it, put the bolt back in jacked up - carefully as it's an alloy sump and easier to strip than metal - and put it back flat to get the oil level right.
Easy job, and something I am doing every 7500k's outside regular warranty services.
Make sure you change the air filter element every so often too, it's common to overlook and lowers performance and raises fuel consumption. Scary at $1.70 plus a litre!
