Results 1 to 10 of 48
Thread: Injector clean
    Adelaide hills, SA
    I've tried Lucas Fuel Additive; filled up 6 days ago.
    Lucas Fuel Treatment : Lucas Oil
    As per instructions, I put 330ml in the T5’s fuel tank and filled up. I have to admit that the blue smoke from the exhaust on first start up in the morning is completely gone.
    The word of caution!
    If your diesel has DPF box, I wouldn't use it, since I don't see any note on the product label that it is suitable for vehicles equipped with the DPF. But that's only me, you make your own decision.
    May 2007
    Thanks to Transporter for the info.
    I have found this link a bit more helpful as the Wurth site is hard to navigate; Wurth Australia Pty Ltd - The Assembly Professionals
    Search under 0893 567
    http://www.wurth.com.au/cataloguevie...f=A04_0047.pdf
    May 2007
    I have also just tried a bottle of the Liqui Moly SPEED TEC Diesel whilst I wait for the Wurth products.
    I must say it is pretty good! Sells for $20 - $25 at various Supercheap / autObarn retailers.
    LIQUI-MOLY Fuel and Oil Treatments & Additives
    Out of interest, has anyone tried the Liqui Moly TOP TEC 4200 5W-30 engine oil?
    It has the following approval VW 504.00/507.00.
    I am interested in trying it...
    Adelaide hills, SA
    Quote Originally Posted by ope126 View Post
    Wurth Australia Pty Ltd - Catalogue
    Yes, I know they don't have the best website and that link in pdf The assembly professionals is changing every month, so it's hard to quote their specific information. As for Liqui Moly oil, if it has MOS2 in it, it would be probably the best oil for TDI's.
    May 2007
    Here is the Wurth details for SE Qld; Wurth Trade Centre 37 Motorway Cct, ORMEAU P: 07 5549 9500.
    Transporter, as for the Liqui Moly oil and your question around MoS2, here you go; LIQUI-MOLY Fuel and Oil Treatments & Additives
    Adelaide hills, SA
    Yes I know, it is great stuff I'm already using LM Engine Protect (Mos2) in all our rides except Tiguan (still too soon).
    May 2007
    Did a little more research and contacted Liqui Moly Australia today.
    They have advised that they no longer import the Speed Tec Diesel. Only what is available in retail outlets.
    After speaking with a rep, they sent me an email with the Technical specs of the Liqui Moly Diesel Anti-Knock Plus. FUEL ADDITIVES
    According to the spec sheet it is safe to use with DPF's.
    This looks more like a cleaner than just a booster of the Speed Tec.
    What are your thoughts on the Diesel Anti-Knock Plus?
    PM me if you want me to send you the PDF Spec Sheet.
    Unfortunatley I am unable to add to this thread.
    May 2007
    I have used the Liqui Moly Diesel Anti-Knock Plus; seems all good so far!
