Originally Posted by
Diesel_vert
There's your answer... assuming there's nothing mechanically wrong with the car.
Bigger wheels and tyres means bigger mass, so more energy is needed to get them rotating.
Bigger tyres also means bigger width and performance tyres, which increases rolling resistance, so more energy is needed again.
19" wheels on a Golf also increases its ride height, making it slightly less aerodynamic, which also costs you energy through increased drag at highway/motorway speeds.
I think the OP already covered that possibility.
Willo - you will/can get a million possible answers on here for something like you've described, including fuel quality, DPF clogging, faulty parts etc.
Tell us a little more about the specific circumstances of your increased fuel consumption - like where you fill up, how often, how much you drive, where/how its serviced etc.
If you can, take it to a specialist mechanic and get the car scanned with VCDS for faults. This is pretty much the most sensible thing you can do first off if its easy.
***EDIT*** since your in Gosford, I can even scan it for you on the weekend if you like. pm me if your interested.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
