My fuel temp sensor loom is almost as short but I have the 125kw TDI.
So today i was under the bonnet doing a diesel purge (story for another time) and noticed what i believe are two issues.
The first issue is:
It appears to be some sort of bracket that isn't hooked up to anything? I cant seem to figure out the purpose or location of where it mounts. Any ideas?
the second issue is:
Surely the wire to this sensor shouldn't be that stretched? There is no slack at all!
[edit] I believe this is the fuel temperature sender.
BTW I reckon that bracket is just left blank i.e. nothing is missing. It could be a thing that's cheaper to bolt on with nothing attached rather than remove it for assembly.
If it all works, just keep on keeping on.![]()
