Yeah you can alter the idle via the ecu. Best to have a quick scan to check all the sensors are behaving at operating temp. Shouldnt be too much going on there mate good set up on the 2.5.
A scan will pull any codes too if any.
Hi there,
Is the Idle adjustable on a TDI 2.5 T4? Or is it only done via the ECU?
My T4 has a habit of idling at around 990-1000rpm when hot, but idles nice at 870rpm when cool-cold. Perhaps a sensor has kapput someplace?
Any ideas?
Thanks in advance.
Peter
Alba European
Jimmy,
OK - so this scan, who can do this? I don't live near any VW centre/workshop.
Live on the south coast (NSW).
Can't do it with a laptop?
Peter
you need VAG Com which lots of people have
go to Golf Loon im sure he'll scan it for you
Or you can come to Canberra, both our shops(Canberra Vw Centre)have the latest VagCom facilities,and would only be too happy to help out another forum member.
Peter
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
Good onya APR!!!!
CHeers
Alba European
Sounds Good APR (?)
Do have a phone number for the VW centre?
I'll put it on my list to do next when I'm in Canberra.
Do you work for them?
I'll need a belt change soon also, pump & timing.
Peter
