Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: How to tachofy your Mk 1 diesel
    what an amazing write up!!!
    need more people like this on here.
    thanks for sharing....i am just gutted i dont have a mk1 derv to try it out on lol
    keep up the good work
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Gosford Central Coast NSW
    Quote Originally Posted by hiho View Post
    I have installed the petrol cluster into my Mk1 diesel and now have a working tachometer! It isnt very exciting to watch, the needle can go all the way to 7000 but rarely moves past 2500. Photos and a description of the process to come.....
    but... i used to rev my old 1.5 out a long way.... from the sound of it, atleast to 5000. you need to turn up the fuel a bit
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2007
    Eastern Suburbs Melbourne
    mines pretty revvy too, maybe that's just the way I drive.
    Does anyone know what the rev 'dots' on the speedo indicate for engine speed?
    i like volkswagens
    maximum
    '99 A4 Quattro 1.8T
    S.E Melbourne
    Mine feels pretty revvy too... but again I think it might just be the way I'm driving it.
    awesome mod, though you lost me once you get to moding the tacho bit will have to get the parts and try my hand at it.
    It doesn't matter what car you drive.. If you're a complete wanker.. People still won't want to talk to you..
    Jun 2008
    Melbourne Aspendale
    I was wondering if it is at all possible to use an aftermarket taco with a shift light rather than mod a mk1 unit.
    The reason i ask this is because i use biodiesel and have been contemplating setting up a simple water and methonal injection system. If an after market taco with an adjustable shift light that would act as a sensor to turn on the water injection would be awesome so that the system only works part time at high rpms...
    I am currently playing around with water and methonal on a mercedes 300D using the auto kick down switch which works ok, however if you kickdown and the revs have not built up it nails for a bit before it gets going. I am using a 97 commodore windscreen washer bottle as i was told they had the most pressure. and i am playing around with cheap misting nozzles from the gardeing section at bunnings.... so far i have spent around $25...
    Since installing the water injection on the merc a few weeks ago it does seem a little quieter, easier to start... aswell as a bit more get up and go... Id love to set one up on my Mk1 golf.
    And again thanks for the awesome write up.
    1980 GLD
    1979 300D Mercedes
    1980 300TD Mercedes
    1956 Desoto Panel Van... Maybe to comeback to life as a diesel???
    Quote Originally Posted by JustMark View Post
    you should do a little writeup here abou how you did it on your merc. i know theres a whole bunch of guys on here interested including me.
    '99 A4 Quattro 1.8T
    Jun 2008
    Melbourne Aspendale
    Ok for those interested parties here is a quick wright up of my water/ meth injection system.
    This is the Automatic Transmission kickdown switch under the accelerator
    This is the splice after the switch which activates the washer pump when the switch is pressed.
    Here is a 97 commodore washer bottle tucked under the cold air intake. The yellow knob is the flow control valve so that i can adjust the amount of injection. I have set it up so that it sprays just under 300mls a minute. I grounded the neg side of the washer pump under the cold air intake.
    After playing around with a few nozzles (i.e. different brands) i found this POPE nozzle from Bunnings.
    And a close up of the nozzle.
    1980 GLD
    1979 300D Mercedes
    1980 300TD Mercedes
    May 2006
    Maroubra NSW
    I tried to do get the tacho working with a PIC once. You've done it with all the existing gear. Good stuff!
    Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
    1976 LS parts vehicle
    Used to have: Mk1 Swallowtail LS DIESEL!
    Apr 2009
    Brizvegas QLD
    Kuddo's
    Kuddos to u ....
