Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: How do I look after my Diesel?
  1. #41
    Dec 2009
    Kew, VIC
    Quote Originally Posted by blameturner View Post
    Just to confirm, should I let the temperature reach it's norm before I start driving or drive very conservatively until it hits the running temp
    Although diesels stand up to it better (you see trucks doing it all the time, and they still do heaps of K's between rebuilds), prolonged idling isn't good for any engine — just get in and drive it.
    Probably you could avoid full-throttle operation for the first five minutes or so, and I wouldn't let it lug in too high a gear, but there's not really very much damage you can do from the driver's seat.
  2. #42
    Apr 2009
    Northern Tasmania
    One thing worth getting for a diesel is a mis-fueling device like this. Stops you putting petrol in because the petrol nozzle can't go in.
    The Fuel Angel - The Misfuelling Prevention Device
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  3. #43
    Sep 2008
    Quote Originally Posted by Ryeman View Post
    Is there a know diesel fuel retailer that doesn't meet VW min specs?
    I think it is the other way around. The fuel engineer from BP said CN and CI are near enough to the same:
    >The reference to cetane number/index is normally used quite
    >interchangeably - I believe that there are very few facilities that
    >have the actual equipment available to test for cetane number and so
    >cetane index is normally quoted.
    >The current specification for BP Ultimate Diesel is for a minimum
    >cetane of 46, though the typical value is usually around the 52
    >mark.
    Theoretically, no diesel in Australia meets the VW spec 51CN. Often the local diesel would be near that, but the specification in the diesel standard is lower at 46.
    So I theorize than the under-spec diesel contributes to higher soot and DPF clogging.
    A cetane improver makes sense. BP Ultimate pre-2010 had a nitro cetane improver and min cetane 50 typical 55, but not since 2010. The highest readily available higher cetane diesel is probably Caltex Vortex with biodiesel (last I looked only in NSW). I saw today Mobil is selling "Special Diesel" - sound similar to BP Ultimate additive package sound like antifoam and injector cleaner at least. European EN590 diesel standard permits a small amount of biodiesel to B7.
    I use Morey's diesel smoke killer as suggested by Transporter. It has an algicide, too.
    2015 Polo Comfortline 6M + Driving Comfort Package
    2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
    (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
  4. #44
    Feb 2014
    Central Vic
    I filled up at a BP but it didn't have an 'Ultimate' sticker on the pump and the lady said she'd find out whether it met Ultimate specs.
    is there a 'basic' BP diesel?
  5. #45
    Sep 2008
    Standard diesel is what everybody gets. Ultimate diesel is the same fuel with additives - the product specification mentions anti foam, injector cleaner, lubricity improver, corrosion inhibitor. (But that is a different list from what I remember from the BP engineer who talked about the BP Ultimate launch. I thought there were 4 and one was the cetane improver, now deleted due to potential risk of storage prior to adding to fuel.)
  6. #46
    Dec 2007
    Diesel ultimate has "typical" cetane of 52, minimum of 46.
    http://www.bp.com/content/dam/bp-cou...ate_Diesel.pdf
    Gone: 2009 MkV GTI DSG United Grey; 2005 MkV Comfortline
    Current Rides: 2020 Mk7.5 GTI Performance ; 2013 MY14 V6 Touareg 180TDI
