Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 46
Thread: How do I look after my Diesel?
  1. #31
    Quote Originally Posted by Greg Roles View Post
    Drive it normally, and try and get a feel for when it may be regenning the DPF, usually a raised idle is the only indication in the latest cars. At that time a 10km long drive is smart, but the idea of doing a random highway drive will do little, unless you only do short inner city trips.
    Is there a way to detect DPF Regens other than guessing as you suggest? So VW do not include Regen Light on dash lol
  2. #32
    Adelaide hills, SA
    Quote Originally Posted by Polo GTEye N9 View Post
    With the scanner only. Otherwise you're just guessing as Greg said. On average under normal driving conditions the ECU will run the regeneration every 900km if the conditions are right. Most owner's don't even know that they have the DPF or what is it. No need for a light to tell that the DPF is regenerating.
  3. #33
    Jan 2008
    Sunshine Coast
    I can't pick them in my MK6 engined Yeti, the only stock way is to watch the oil temps on the MFD, it jumps up 10 degrees during a regen. Not something you need to worry about, the DPF system on the MK7 is very advanced, massive, and should last a long, long time.
  4. #34
    Feb 2014
    Central Vic
    Does the 'range' remaining take a dive with a regen?
  5. #35
    Jan 2008
    Sunshine Coast
    Nope, not in my experience.
  6. #36
    Feb 2014
    Central Vic
    Mines got a 'box' which makes the MDI hopelessly optimistic.
  7. #37
    Feb 2010
    N.E.Victoria
    Don't baby it to much, that can sometimes be worse than thrashing it, just drive it.
    Let it come up to running temperature before you give it the boot.
  8. #38
    Mar 2015
    Kellyville, Sydney
    Quote Originally Posted by Ryeman View Post
    haven't noticed it no.
  9. #39
    Mar 2015
    Kellyville, Sydney
    Quote Originally Posted by twincab View Post
    Just to confirm, should I let the temperature reach it's norm before I start driving or drive very conservatively until it hits the running temp
  10. #40
    Feb 2014
    Central Vic
    Quote Originally Posted by blameturner View Post
    The quicker you get the oil temp up the quicker the 'anti-wear' properties of the oil kick in - drive it conservatively straight away.
