Yeah, I'm over two stroke oil discussions too. Just use it or don't. Next.
A diesel is no different, but fuel is probably the biggest thing nowadays. I would suggest using BP or Caltex, as they add cleaners to help keep injectors in top shape, but I'm sure Shell is fine too. I avoid all the no name and cheap diesels utterly.
Supercheap has Moreys Diesel Smoke killer, which is probably just two stroke oil, but it's all the additive you'd ever need.
A catch can is a great idea, but is a DIY and does take a bit of tinkering ability.
A tune on a TDI is a massive jump, any of the decent brands will give you a fun result. If you have warranty and its a late model, you have to consider the fact the dealer automatically detects OBD flash tunes and keeps that on file. There are other methods around that.
Drive it normally, and try and get a feel for when it may be regenning the DPF, usually a raised idle is the only indication in the latest cars. At that time a 10km long drive is smart, but the idea of doing a random highway drive will do little, unless you only do short inner city trips.
Welcome to the joy of oily hands at the diesel pump, and just make sure you never zone out and put petrol in it. Much badness.
