Results 1 to 10 of 14
Thread: How big is too big?
    How big is too big?
    down the track i want to let the Pogo breathe a little easier.
    how big is too big an exhaust (turbo back)?
    i was thinking 2.75" turbo back.
    thoughts?
    Jun 2006
    Orange NSW
    4 inch is probably too big...
    Gosford Central Coast NSW
    its not much engine (1.9l) and not too much high rev's boost to warrant more than about 3". 2.75 will be exxy, since the size is less common. 2.5" will be big enough and much easier - hence cheaper - to fab.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    sounds good mate thanks for that
    i can get metal straight from the source basically and at a good price through my TAFE. I'm very tempted to go stainless and will definately go mandrel bent and i will flange it in 3 spots like my mk1 for ease of removability
    Nov 2007
    The Land of Oz
    Bigger at both ends
    G'day, Josh.
    Don't forget the air going in, too. I just fitted a pod filter (K&N) to my Landrover Discovery Tdi and the difference is phenomonal! She just breathes easier overall, but it's most noticeable when the turbo is on boost (as you would expect). A nice bonus is being able to hear the whistle of the turbo quite clearly so you know when it's spooling up and on boost. Surprisingly, there's no noise penalty as induction roar. When my TDI is out of warranty it'll be the first mod that I do
    (Sorry asbout the non-VW pic you guys...Moderators, feel free to delete.)
    Quote Originally Posted by cetane View Post
    its got a VAG engine - good enough for me
    '99 A4 Quattro 1.8T
    Quote Originally Posted by GoLfMan View Post
    please please dont waste your money on stainless..... its realyl not going to be worth the extra cost.... diesel exhausts just dont deteriorate like petrol ones do, since theres always so much gas flow (no throttle) water never condenses in there... so unless your going with stacks just use mild steel.
    just my advice
    '99 A4 Quattro 1.8T
    G'day, Josh.
    gday cetane!
    i've already done the intake, not a pod filter but a Seat intake and later on will get myself a K&N it was noticably smoother when i fitted a new intake not just have to make the other end breathe just as well!!!!
    just my advice
    good to know, im just newish to the diesel game so i didnt know this fact
    in that case ill get mild steel! ill price up 2.75" and 2.5" piping and if the difference is massive ill get the 2.5 but if its just a little bit more ill fork out and get the bigger stuff
    more than likely however ill just get the 2.5", ill do cat back first then a dump pipe.
    Nov 2007
    The Land of Oz
    Agreed
    just my advice
    And mine too!
    Over 40 years of diesel ownership and I have NEVER had to replace any part of an exhaust system and Ayden.. Part of the reason is the layer of carbon that forms on the inside and protects the metal from corrosion
