4 inch is probably too big...![]()
down the track i want to let the Pogo breathe a little easier.
how big is too big an exhaust (turbo back)?
i was thinking 2.75" turbo back.
thoughts?
its not much engine (1.9l) and not too much high rev's boost to warrant more than about 3". 2.75 will be exxy, since the size is less common. 2.5" will be big enough and much easier - hence cheaper - to fab.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
G'day, Josh.
Don't forget the air going in, too. I just fitted a pod filter (K&N) to my Landrover Discovery Tdi and the difference is phenomonal! She just breathes easier overall, but it's most noticeable when the turbo is on boost (as you would expect). A nice bonus is being able to hear the whistle of the turbo quite clearly so you know when it's spooling up and on boost. Surprisingly, there's no noise penalty as induction roar. When my TDI is out of warranty it'll be the first mod that I do![]()
(Sorry asbout the non-VW pic you guys...Moderators, feel free to delete.)
please please dont waste your money on stainless..... its realyl not going to be worth the extra cost.... diesel exhausts just dont deteriorate like petrol ones do, since theres always so much gas flow (no throttle) water never condenses in there... so unless your going with stacksjust use mild steel.
just my advice
'99 A4 Quattro 1.8T
good to know, im just newish to the diesel game so i didnt know this fact
in that case ill get mild steel! ill price up 2.75" and 2.5" piping and if the difference is massive ill get the 2.5 but if its just a little bit more ill fork out and get the bigger stuff
more than likely however ill just get the 2.5", ill do cat back first then a dump pipe.
