Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: How bad is it having a dying DMF?
    Aug 2011
    vic
    Quote Originally Posted by asa572 View Post
    Vraptor,
    is your car a manual or DSG?
    It's a DSG, how come?
    I have just been quoted $2255.00 to replace my DMF, and recommended an additional $500 to replace the starter motor too. Is that normal?
    Dec 2008
    Sydney/Canberra
    Yeah, the DMF for them is pretty pricey. I'm not aware of any sort of SMF kit to suit the DSG.
    As for the starter motor, what's wrong with it?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by vraptor View Post
    You will be pushing **** up a hill to get a SMF for a DSG. I have seen them made for petrols with DSG's but if you put one on a Diesel with a DSG you would probably stuff the gearbox in no time.
    As for the starter motor, who told you it probably stuffed the flywheel?
    A starter motor will not wreck a DMF.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
    Dec 2008
    Sydney/Canberra
    Slow crank, is probably why. Common issue with the TDIs.
    I'd be inlcined to leave it be, for now. If it starts to cause issues down the track, it's only a 20min job to swap out.
    '01 Beetle 2.0
    Aug 2011
    vic
    Quote Originally Posted by Umai Naa!! View Post
    It's only a 20 minute job to swap out the DMF?
    The mechanic has told me that often a faulty starter motor can lead to the DMF failing and losing it's spring due to the vibrations on a slow startup. I've had battery issues before that have apparantly caused issues to my starter motor and in turn the DMF. This is what I am being told at Volkwerke
    Dec 2008
    Sydney/Canberra
    No, the starter is a 20min job.
    '01 Beetle 2.0
    Aug 2011
    vic
    My car does struggle to start one or twice every month, it will take a while to start. It seems to be electrical but im not sure.
    Aug 2011
    Lake Macquarie
    Sorry but that explanation to why the DMF failed is laughable to me.
    I'm out now.
    MKV Jetta FSI DSG
    Aug 2011
    vic
    I'm out now.
    It sounded a bit crazy for me too, however Volkwerke are pretty reputable so im not sure.
