If they are well maintained the VW TDIs seem to go for a long time, and with highway use like you are describing yours should last very well.
Be fanatical about changing the engine oil (+ filter) at the correct times and with the right oil (I would use oil approved to VW 507.00 standard)
I can't remember all the details (my 5 cyl TDI has gear driven cams), but I seem to have an idea that some VW 4 cyl engines need the water pump replaced at regular intervals (but that may be only the 4 cyl petrols), and when the timing (cam) belt is changed you should get a full kit which should also include a tensioner and some bolts (and maybe some other stuff ?)
Did you consider a Polo 1.9 TDI ? IIRC they get even better fuel economy than the Golf, which may be significant given the miles you do.
