![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Biggles
I've been trying to ascertain whether my '05 T5 128kw diesel has cam belt or chain.
Hello Biggles,
Yes, I'm quite sure the T5 R5 2.5l 5cyl engine is gear driven. It was one of the reasons I bought it (no possibility of a rubber belt breaking and wrecking the engine, plus reduced maintenance requirements and costs.
Of course they do have those tricky little flexible drives (special belts) for the alternator and air-con pumps, and these DO need replacement at regular intervals.
Also the R5 engines (like all VW TDIs) are very fussy about using the correct oil and changing it regularly.
If you do a bit of snooping on the brickyard forum (link below) you will find out a LOT more about T5s, including things to be wary of (eg replace the waterpump on early T5 R5s ASAP if it hasn't been done already).
http://www.brick-yard.co.uk/forum/default.asp
