Results 11 to 20 of 34
Thread: Hesitation under light throttle, has anyone experienced this?
    Sep 2008
    Couldn't it be sticky vanes on the turbo? (In which case if you regularly rev it a s per the guidelines, it should go away.)
    Why would a 7500km service make any difference? wouldnt it be an oil change and flog around the block?
    Last edited by gldgti; 04-11-2008 at 09:56 PM. Reason: Sorry, accidentally edit instead of quoted, my bad.
    2015 Polo Comfortline 6M + Driving Comfort Package
    2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
    (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
    Gosford Central Coast NSW
    Quote Originally Posted by bluey View Post
    As stated earlier - it is highly unlikely the turbo has any real effect on engine performance below 1500rpm.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jan 2008
    Sunshine Coast
    Mine feels eggsactly the same. To me it's most obvious as being "unhappy" at partial throttle at about 1700rpms, just before boost, where it tends to surge a little if driven quietly in this off boost range. Only find this on partial throttle situations, and I figure it's just the "turbo lag" thing and no big deal. But then again I manned up a while back, so perhaps that's the answer?
    Sep 2008
    Can I presume this is happening crawling along in peak hour traffic? No sign of it yet for me. I can't say I can detect any turbo lag at all, but that might be the difference between 8 valves and 16 since 16 should have less torque at low revs.
    Jul 2005
    Newcastle, NSW
    It happens for me at any speed above 50km/h under light acceleration, most evident around 65-70 in 4th.
    Quote Originally Posted by mikinoz View Post
    Mine does it too, just like the car above..
    had it back to VW and they replaced a few seals, they reckon in the inlet system, it still does it, but not as much.
    I noticed it at around the 20000k mark. Car has done 35000k now. must be an idiosyncrasy of this motor!
    Just make some soot and it goes away
    Mark V 2006 MY07 2.0Tdi Comfortline 6spd/Man
    Mark IV 2001 1.6L (SOLD)
    Sep 2008
    TDI Club FAQ section 8q mentions sticky EGR valve as possible cause of hesitation. It also suggests a preventive fix to recalibrate the engine management to allow more air which reduces the sticky soot buildup. It also says that driving at that engine speed is "improper use of the transmission".
    Feb 2008
    Adelaide,Oz
    new to this, but,
    faulty MAF sensor? any codes?
    Steve
    04 T5
    Feb 2008
    Brisvegas
    Quote Originally Posted by Rebuild View Post
    new to this, but,
    No, its not that serious. Its a hesitation not a fault
    Cheers,
    Jamie
    Jan 2008
    Sunshine Coast
    Any hesitation in acceleration is a fault!
