referring to a part of the rev range that i would say isnt included in normal driving - i would make light of the fact you have yourself identified that it is a very light "throttle" - a setting where you could be slowing down, easing off, etc.
remember that the ECU doesnt know what you are going to do next - the only information it gets is your input and current curscumstances - ie accellerator position, and all the things it measures that the engine/drivetrain is doing at that instant.
i am reminded of driving mischa's GT, and stalling it - being used to my old IDI, no computer diesel. because the mk3 is governed by linear springs and flyweight mechanisms, there is a combination of linear control responses to any accelerator position - but all of these equate to the injector pump wanting to put more fuel in the cylinder - and hence, at idle, there is useable torque, and its a seamless progression as revs go up.
the digital equivalent system that your ECU replicates is not bounded by springs and weights, and so can be non-linear (read, piece-meal) in its control response. as a result, it is probably programmed to give little to no fuel at very light accelerator settings, so as to minimise fuel usage, for example, during gear changes, and when transitioning between cruiseing and braking.
i would very much rule out anyhting related to boost pressure - even the VNT on your TDI wont make useable boost until you're adding a reasonable amount of fuel to the mixture ESPECIALLY under 1500rpm, and so does not apply for "light throttle settings"
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
