Results 1 to 10 of 33
Thread: help wrong oil in TDI
angeniang help wrong oil in TDI 21-04-2013, 11:43 PM
Umai Naa!! If you have replaced the oil... 22-04-2013, 12:45 AM
Diesel_vert Any effect on the engine and... 22-04-2013, 01:35 AM
Guest001 Probably should have changed... 22-04-2013, 07:38 AM
Transporter I agree , too late know. The... 22-04-2013, 07:50 AM
    i did a big mistake
    i have changed Castrol Edge Engine Oil - 5w-40 in my 9000KM GOLF2.0tdi yesterday and have run about 400km
    i refill oil with VW 507 standard today
    do i need go to dealer to check the car, i feel the engine noisy not like before, i worry about the DPF is damage.
    anyone can give some advise to me?
    Dec 2008
    Sydney/Canberra
    If you have replaced the oil with the correct one, you should be ok.
    There isn't much else you can do.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2009
    Any effect on the engine and its emissions systems will most likely be very minimal, if any.
    Pacific Paradise QLD
    Probably should have changed the filter as well Too late now though
    Adelaide hills, SA
    I agree , too late know. The oil filter can hold up to 0.7L if you suck the oil out from the o.filter housing as well. Going to the dealer would just give them an excuse to void your warranty on the emission system, mainly the DPF. So, I suggest you don't tell them.
    thanks yours suggestions
    so i better going to dealer now or
    continue run another 5000KM then to do a normal service with dealer later????
