I'm with Russ - faulty brake light switch. It is a very common problem with VWs in the US, and I think they gut up to the 4th revision before getting it right. Do a search on TDI club, there's heaps of info about it there. The older revisions can be stuffed up when you fit them unless you follow the correct procedure.
Mind you, it could still be related to something that the Auto electrician did, but assuming you checked the lights and used the brakes before you got home it is less likely than the brake switch.
Hope you get it fixed quickly and without too much drama, let us know how you get on.
