Results 1 to 10 of 17
Thread: Help please! My diesel stopped working!
    Jan 2007
    Just had a set of HID lights put in to the T5 Multivan.
    We drove the 5K's to home without any diffic ulties.
    Last night I fired up the lights to see what they do. Had the T5 idling in the driveway while I checked the light output with my light meter when the engine just stopped without warning, and the "coil" warning light came on on the dash.
    Now the engine will turn over with the battery, but the engine will not start.
    What could be wrong?
    Is it possible that something the auto electrician did caused this?
    Is it worth getting the RAA out to have a look?
    Thoughts please?
    Oh - and Happy New Year to all.
    Golf V TDI 2005 - SOLD
    Volvo C30 D5 - I've got a hat as well!
    Multivan Highline T5 TDI 4Motion 2005
    Hond Civic VTI 2001
    Jun 2008
    South Coast N.S.W.
    Happy New Year also !!
    Could just be a coincidence, I had a similar situation with tow bar wiring and blowing brake light globes with the trailer plugged into the new socket, turned out to be the brake pedal switch (EF Falcon, common problem apparently ).
    I would probably be taking it back to the installer though and getting them to check their work, by the sounds of what I have read about VW electricals, they are brilliant, but as soon as someone makes changes to something there could be issues with something else.
    Russ
    Russ
    2005 Subaru Outback 3.0 R Premium
    Jan 2008
    Sunshine Coast
    My best guess is the guy has taken power from the engine circuit somehow, and it's tripped the computer. HID, fogs etc draw more current, so perhaps he went looking for larger wires for power? What I can say is now that I've put an aftermarket stereo in the Golf, the wiring is not straight forward, the CAN-BUS system sends all sorts of pulses and signals down common wires, and isn't like cars used to be. Very complicated electrically.
    Even a simple stereo power and ignition input was not easy, and I've done several major ones over the years.
    Jan 2007
    Just had a chance to read the manual. It says that there is a problem in the engine management with the Glow Plugs.
    Could the installation of the HID lamps cause the engine management fault?
    Hond Civic VTI 2001
    Jan 2007
    South Australia
    Its a annoying thats its NY's Day.
    Have you called VW Roadside Assist yet ?
    Other wise wait till tomorrow and see if Solitaire can help
    Good Luck Rod
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Jan 2007
    Thanks Ben,
    VW Roadside assist ran out in July, and we didn't get extended warranty
    Hond Civic VTI 2001
    Jan 2007
    South Australia
    Quote Originally Posted by shogun2 View Post
    Thanks Ben,
    RAA then ?
    I'd wait for Solitaire to reopen if possible.
    - Ben
    2008 Jetta 2.0L FSI
    Canberra
    I'm with Russ - faulty brake light switch. It is a very common problem with VWs in the US, and I think they gut up to the 4th revision before getting it right. Do a search on TDI club, there's heaps of info about it there. The older revisions can be stuffed up when you fit them unless you follow the correct procedure.
    Mind you, it could still be related to something that the Auto electrician did, but assuming you checked the lights and used the brakes before you got home it is less likely than the brake switch.
    Hope you get it fixed quickly and without too much drama, let us know how you get on.
    VAG-COM it for faults before making a decision on where to take it.
    If you need to borrow one, mine isn't busy today.
    Jan 2007
    Unfortunately, difficult to take back to the installer, unless it's on the top of a tray truck ...
    Hond Civic VTI 2001
