Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Help please! My diesel stopped working!
    Jun 2008
    South Coast N.S.W.
    Quote Originally Posted by gregozedobe View Post
    I'm with Russ - faulty brake light switch. It is a very common problem with VWs in the US, and I think they gut up to the 4th revision before getting it right. Do a search on TDI club, there's heaps of info about it there. The older revisions can be stuffed up when you fit them unless you follow the correct procedure.
    Mind you, it could still be related to something that the Auto electrician did, but assuming you checked the lights and used the brakes before you got home it is less likely than the brake switch.
    Hope you get it fixed quickly and without too much drama, let us know how you get on.
    Greg I wasn't saying that the problem in this case was a faulty brake light switch, I was only using my experience with the faulty brake switch as an example of coincidence. I think the idea of running a check for faults is probably the best option. Good luck with it Rod !!
    Russ
    Russ
    2005 Subaru Outback 3.0 R Premium
    Jan 2007
    With many thanks to Gavin for the use of his Vag-Com:
    18071 - Control Circuit for PD Injectors: Short to Plus
    P1663 - 000 - - - MIL ON
    Freeze Frame:
    RPM: 840 /min
    Torque: 36.6 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 13.98 V
    Bin. Bits: 00001100
    Temperature: 36.0°C
    Bin. Bits: 01010000
    18009 - Relay for Supply Voltage Terminal 30 (J317): Implausible Signal
    P1601 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.32 V
    Bin. Bits: 00001100
    Bin. Bits: 0
    (no units): 0.0
    Don't know whether the second one has any relevance to the fault, but the first one certainly does. Can anyone suggest possible causes?
    Golf V TDI 2005 - SOLD
    Volvo C30 D5 - I've got a hat as well!
    Multivan Highline T5 TDI 4Motion 2005
    Hond Civic VTI 2001
    I'd say it was wiring Rod.
    A job for an auto electrician. A short to Plus doesn't sound to be good. Although, the way VAG-COM works, it has to base it's diagnosis on a wide range of possibilities and I don't think they include wiring problems in that process.
    The way it flags boost leaks on 1.8Ts is a good example. It points the digital finger at the DV when it is just as likely to be a hose clip loose. They have to assume a certain amount of things don't fail I guess.
    Jan 2007
    All the little clues add up.
    I looked at the forum link, and it mentions an external tuning box. I have the Digi PD box from diesel-power.com. I have removed the box (which I was going to do anyway), and all it now well!
    Thanks especially to Gavin, and all others who provided comment.
    Cheers, and Merry New Year!
    Hond Civic VTI 2001
    Jan 2008
    Sunshine Coast
    Now THAT'S what these forums are all about. Nice to see!
    Quote Originally Posted by shogun2 View Post
    SWEEEEET!
    The power of the 'INTERNET' never ceases to amaze me!!!!!
