![Emo Duh](https://www.vwwatercooled.com.au/forums/images/smilies/emo_duh.gif)
The verdict is in, the local Volkswagen Dealership reckon the turbo has blown and needs replacing along with the intercooler and the front and rear exhaust including the catalytic converter, it and the exhaust are swamped and contaminated with oil. Why would you need to replace your exhaust? The cat maybe but surely you could wash out the exhaust with a solvent (or at least the straight pipes?).
They do not believe the motor is damaged but until they get a new turbo on it they won't know!! So it's a case of suck it and see.
Anyway the price to supply and fit a new turbo, intercooler and exhaust is $8972!!!
![Eek](https://www.vwwatercooled.com.au/forums/images/smilies/eek.png)
Does this amount seem right to you guys?
This dealership (John Hughes Volkswagen) are not interested in helping out in any way as the car is 3 months out of warranty. Too bad that a volkswagen turbo has detonated with only 79,000km on the clock with no explanation, it's out of warranty so I'm on my own. They even went as far as to say the car has had several owners (they later conceded that I was only the second) and that either one of us could have been using Bio Diesel (I only use BP Ultimate diesel). Then they suggested that the car had not been regularly serviced stating that it hadn't been serviced since 54,000k! After arguing with them they conceded that they had in fact performed a major service at 54,000k and that they had a record of when I phoned up about the 70k service when they recommended leaving it until 75,000km!
I sincerely hope that all VW turbo owners don't suffer the same fate as myself where your turbo dies a few months outside of the warranty period because it makes a Golf TDI a very expensive car to own and certainly negates the potential fuel savings that you might make over an extended period.
Personally, even if the motor is ok, how can I have faith in the next turbo or any other part of the car for that matter? This is my third turbo car, I've had a Mazda and still own a Toyota both with far more K's than the golf (the Toyota is a 93 model) and I've had no turbo issues whatsoever before this.
It leaves a very bad taste in your mouth
![Sad](https://www.vwwatercooled.com.au/forums/images/smilies/icon_sad.gif)
