Results 1 to 10 of 16
Thread: Help installing intake? (Melbourne)
    Aug 2011
    vic
    Hey guys,
    Wondering if anyone is experienced with intake installation on a TDI?
    And if there's anything to watch out for? ie what to do with the filter, etc? (as i heard not to use oiled ones? i dont even know what mine is.....)
    thanks
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by vraptor View Post
    Hey guys,
    thanks
    Sorry to miss your PM's, not on here often.
    Installing an intake on a TDI is pretty much identical to a GTI, and it's not a complex thing to do. I'm afraid I don't have a "how to". Perhaps you can ask 42DD, but they can be slack on doing up instructions. Best idea would be to look on youtube for a GTI intake install video, as you have to do is remove the stock intake back to the MAF housing, and then fit the aftermarket one in it's place, it just clips down to the stock factory mounting points, I think you have to swap over the stock box bottom rubbers. The filter element is oiled, and it's ready to go.
    Actually here is a somewhat similar intake, doesn't show the standard box coming out, but it does show a similar rubber hose to the MAF housing beside the battery like the 42DD. https://www.youtube.com/watch?v=xEtasrVwN-E
    Here is getting the stock box out, only need that part, the rest is all GTI petrol engine specific and you are just mounting onto the MAF beside the battery.https://www.youtube.com/watch?v=CJ_gf_h8j3U
    If this is still beyond you, I'd suggest going to a meet night, where lots of guys can help you in person, or finding a good recommended VW mechanic, who could do this pretty easily.
    Aug 2011
    vic
    Quote Originally Posted by Greg Roles View Post
    Thanks Greg,
    All good, my main question was around the filter? as I thought the oiled filters were not good for our diesel engines...
    Should I be using a dry filter?
    Adelaide hills, SA
    The factory filter is very good, not worth of changing for something else. If you go for a wet filter make sure it's oiled properly - not too much, and clean the MAF sensor overtime you remove the air filter.
    Aug 2011
    vic
    Well im replacing the whole intake, and the new one uses a K&N cone filter. Which is not dry, and I have heard this is bad for the car? especially diesel, comments?
    Jan 2008
    Sunshine Coast
    Load of rubbish, only a problem if you dramatically overoil the filter and some oil gets on the MAF sensor, screwing up that sensor. I ran oiled filters for years with zero drama, just don't go nuts at clean and reoil time. No other issue to a diesel, and this can happen to any car running a hot wire MAF sensor.
    Aug 2011
    vic
    Thanks Greg, i accidentally went ahead and ordered a dry pod online, at least this means i can install it at the moment.
    So the 42dd filter is all ready to go? what is the recommended clean and re-oil process?
    Feb 2014
    Central Vic
    Reports I've read say that the standard system actually filters better than the oiled ones.....if filtering is the priority.
    Gosford Central Coast NSW
    it has been proven numerous times that oiled cotton 'performance' filters dont filter as well as dry paper filters. They do a good job of certain things, not a comprehensive job though. Its simple enough to see why - they flow more when new because they have much larger pores in the filter material - the oil is there to help trap passing particles - but they always have enormously less total area aswell, which means as soon as they become dirty the performance degrades extremely fast. However, its probably not an issue for anyone that spends most of their time driving in 'clean' areas, like around the city.
    And then there is the risk of over oiling, which I have seen the results of more than a few times - it can happen pretty easily.
    Either way, any airbox mod on a modern golf that isnt pulling over 300hp is really just for the sound fx or underbonnet bling in the end - so as long as it does actually adequately filter your air, then its probably not going to make much difference.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jan 2008
    Sunshine Coast
    Mate read the K&N site, I cleaned it when it looked dirty usually at each oil change. As it is very open it gets dirty fast.
