Results 1 to 10 of 25
Thread: HELP Exhaust Pressure Sensor 1 (G450): Signal too High
Threaded View
  1. #7
    Oct 2010
    2.0 TDI BRE Motor Differenzdruckgeber defekt: Dieselschrauber Community
    This link seems to say that if you go into Coding II and type 11 it will adapt the ECU to the new sensor...
    http://www.vweosclub.com/forums/showthread.php?t=4269
    This details the voltages a guy was getting with a faulty sensor and good one. I wonder if it is possible to replace the sensor with a voltage divider giving the correct pressure reading for a healthy DPF and hollow out the DPF leaving the lambda and temp sensors intact...
    Golf GT Sport TDI
