The bores are probably glazed or excessively worn (oval perhaps). The po probably whacked in the rings hoping that it would fix the problem. If you want to fix it properly you'll have to pull it down and mic the bores to check for ovallity and degree of wear. If you want to take a chance and hope that the new rings just need time to bed in, rig up an extra breather and drive it hard for a whileOriginally Posted by hiho
http://vwwatercooled.org.au/vwforum/viewtopic.php?t=211
Depends on how it blew. Diesels have little tolerance to overheating. If it was just "mildly" overheated then the head may not be warped. A replacement gasket and a careful re torque should do it. If a crack in the water jacket caused the overheating then throw the head away as it will almost certainly be warped.other one has 220,000kms and a blown head gasket. Apparently it ran well before the head gasket went. Ive been told that when the head gasket goes, then the head is stuffed(craked and or warped). Is this true? Is replacing the head gasket difficult, special tools etc. I have the Tractor Manuals Golf manual and diesel supplement to guide me, also the haynes manual is in the post.
Pulling the head is no great issue. You need to make up a locking pin for the injection pump and a plate to lock the camshaft. If you do decide to take it on, let us know cos there are a few tricks that will keep you from grief.
FIX THEM ALLMy options are:
1. hone/rebore the motor with blowby and replace the head gasket on the other
2. put the good head on the good block, put the spare engine in the place of the blowby motor.
3. replace head gasket and live with the blowby in the tired motor.![]()
They're getting too rare to abandon.
7. (You) buy four 1.9TDIs with 5 speeds and give one to me4. Buy a 1.9TDI with 5 speed
5. Buy two 1.9TDI's with 5 speeds
6. Buy three 1.9 TDI's with 5 speeds![]()
I have a number of head gaskets. When you come to do the job look at the notches on the tab between #2 and#3 glow plugs. This indicated the thickness of the head gasket. Ignore at your peril!Any help with the more realistic of these options would be greatly appreciated!
Matt
