Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: has this ever happened to u???
    Aug 2009
    Torquay, victoria
    car: 81 gld
    scenario: driving car at 100k's on the hume, all of a sudden the rev's started going up all on there own even when i took my foot off the pedal, smoke pissing out of the exhaust, probably due to it revving its tits off. i had to turn the key off for it to stop revving. i thought the accelerator cable was just stuck, but the revs were going up and up. started the engine again and it idled fine but then as soon as i pressed the accelerator it went up again on its own. a couple of starts later it didnt do it again and i drove it home
    any ideas what the hell happened?????
    Mindarie, Perth (WA)
    to answer your first question. No.
    Jun 2006
    Orange NSW
    Could be a blowby problem. Because it's a diesel it can run on its own blowby gas if there is enough oil and fuel in it. Next time it does it get out and squeeze the crank case vent hose shut. If the revs drop back down, you've found your problem. I'd suggest changing the oil (because it could be heavily diluted with diesel) if this is the case if you haven't recently to start. After that it's probably time some some new pistons and rings, but let the Mk1 diesel guru's chime in on that one..
    Aug 2009
    Brisbane Sth
    Your Burning oil
    I agree your burning oil or excess fuel somehow, the question is where is it coming from, pull of the crank vent and see how much blowby is coming out at idle. It may have got a dollop of oil down its snot that has been lying around somewhere in the intake system. Id get to the bottom of it quick, or the thing could go bang in front of you. The fact that it turned itself off with the key seems to indicate that the fuel pump is still in control, what color was the smoke black or white? I am assuming there isn't a turbo? The fact it behaved itself at idle and then revved when you gave it more fuel also makes me wonder about the fuel pump. The fuel pump is still unfamiliar to me gldgti or mullins need to chime in
    Spark ignition is a threatened species
    Biodiesel is the best emission control money cant buy
    MK1 5 door Mexico Beige 5/79 Golf GLD 1.5
    Aug 2009
    Torquay, victoria
    there is no turbo and the smoke was black i think
    Aug 2009
    Brisbane Sth
    Ok my guess is?
    Sounds like its getting to much fuel for some reason, without out it being in front of me its hard to tell, when gldgti logs in again he may be able to tell you more about the pump. To much fuel sounds like the problem the question is how? Whats the history of the fuel pump how many K's has the engine done?
    Aug 2009
    Torquay, victoria
    Quote Originally Posted by oracle1 View Post
    not sure on the history of the fuel pump and the engine has done 260,000. before i had purchased it an old guy owned it and hadnt driven it over 75kph for 15 years. this was the first time in a long time it has gone 100kph.
    Aug 2009
    Brisbane Sth
    It may just need a good run however?
    It may be just a little sticky somewhere or it could be more serious. Without doing more research on the pump and knowing how the electric fuel shutoff works, and where/how the excess fuel could be entering the system I would be wary of the engine running away.
    If the electric cutoff doesn't stop the fuel you have a problem. Lets hear what gldgti or the other die/heads have to say and I say that with the utmost respect of course? I don"t have enough experience with this type of pump.
    Aug 2009
    Torquay, victoria
    cheers so far though. lets see what he rest have to say.
    Jun 2007
    Eastern Suburbs Melbourne
    Interesting. I've never had it happen to me at all.
    If it was a blow-by/run-on issue, I believe you would have had issues getting the engine to stop.
    Logically thinking (rough for a sunday night) increase in revs in our diesels, probably means excess fuel. so it's possible you had a slight blow-by from the crank case, or something simple like the accelerator cable being sticky or something.
    I can say I honestly dont' know to be sure though, sorry mate.
    i like volkswagens
