Originally Posted by
Umai Naa!!
It's not always the dealer's call on this. You need to take the issue up with Volkswagen Group Australia.
The $8200 would be the high pressure fuel pump, rail sensors, injectors, misc small single-use parts, like injector bolts, and labour.
The injectors themselves are about $1,000 each, one of the rail sensors is just under $1,000 and the other about $450. There's about 5 hours labour in swapping it all over, plus the initial diagnostic time.
I'd still fight it.
If you look at the reports from North America where the HPFP has failed in CR TDi's, the swarf from the shredded pump not only ends up in the areas listed above but also travels down the fuel recirculation circuit so all the fuel lines and the tank need to be removed and cleaned out as well.
It's a BIG issue which is why someone has come up with a post HPFP filter to contain the swarf in the case of failure which will limit the damage to just the HPFP (Keeping your CRD HPFP alive) .
Resident grumpy old fart
