I assume you mean for mk5?
All the airboxes are the same.
If you want more hp from this mod, don't bother. You will only get increased noise (if thats what your after).
Where can I get a gt sport tdi cold air intake from?? I have found a few but well over priced. Is gti the same fit?
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
After a bit of noise lol, so if I get one for mk5 gti it will fit gt sport tdi??
No.
Airflow-wise, the standard setup is about as good as you'll get. Maybe try a K&N filter in it.
I have this one, and it has a LOT of noise, and flutters a lot, lots of fun.
VW Mk5/Mk6 TSI High-Flow Intake System - 42 Draft Designs
Make sure you ask for the pipe with the vacuum "plug".
How much it cost? You put it on tdi?
It's the same air box you'd be swapping out.
The 42DD intake is not for the faint hearted, people look at you idling at the lights, sounds like Satan breathing. It was actually too much for me to be honest, but for you young ( at heart ) fellas, probably ideal. I don't sell 42DD parts anymore, but easy enough to get direct.
