Talk about shifty, i can't believe you brought your dad to the event. How was the videos he shot!
No problem at all, my friendYes its amazing how much different it feels on the road to what the graphs depict.
This graph shows the difference between Gregs car and mine, both power and torque curves are plotted. Although the output is not the top run my car did on the day & give or take a few kw's for someone leaving the a/c onthe graphs should still have the same curves
This one shows the top run my car did on the day with AFR's.
Greg has sumed up and confirmed by driving my car ,what its real character is. So folks if your one of those people who thinks its all about the numbers & you want a dyno queen then this retune is not for you but if you want something that is really responsive and has plenty of torque over a wide rev range then maybe you should consider this retune.
Cheers,
Jamie
Thanks for the post mate, interesting to print and work out the torque numbers.
What IS very interesting is if the stocko TDI pulls 113kw, and is rated at 125kw, it has about 10% transmission loss. Certainly an efficient tranny, but not outside the relms of possibility for a modern FWD. I suspect the diesel gearbox would be more, as it's supposedly a tough thing, so my folowing summary is probably on the "down" side.
The stock torque rating according to the dyno is about 356nm at the wheels.
At the same 10% loss from above, this puts the fly torque of the stock TDI at about 380nm. Very very healthy.
Given the aircon factor in your superchipped car Jamie, I'd guess you are around the 420 nm mark at the fly.
In all, it sure seems the ol oilers are pulling some impressive numbers where it counts!
