I also used a calculator, not the MFD to state my figures, but the MFD is not that far off, but I agree, it can be a little optimistic.
And given I've only had the car for less than two months, I doubt I'd go back to petrol also. I suspect that the diesel cycle engine will be the way of the future. Even now, they are finding their way onto light aircraft, most notably the Cirrus and Cessna are considering it also.
And how long does it take to don your wet weather gear and take it off (or to change into dry clothes) ? When I used to regularly commute in Melbourne on a bike I used to (sometimes longingly) refer to cars as "the ultimate wet weather gear".
If they are considering running diesel in planes, I wonder how long it will be before we see a TDI motorbike ? Imagine the fuel consumption you could get out of an appropriately designed diesel bike !
Diesels for light aircraft will become more common because AVGAS isn't plentiful, cheap or good for the environment - it contains lead. Some existing aircraft (Cessna 172s etc) can be retrofitted.
Aircraft diesel engines run on Jet A1 fuel. Hmmm . . . wonder how my TDI would run on that stuff!
Do not even think about it as the fuel is too dry (no Sulfur or any lubricating properties). I must admit though when we have had to drain a tank to work on it I will use it in an old tech diesel by mixing in 2 stroke oil until there is an oily feel when rubbed between your fingers. I have used it in the Nissan Grenade as a get out of jail.
Also remember the pressures in the PD injectors is much more than in a turbine engine. The pump output is only 900psi approx and the nozzle working pressures are between 60-150psi on turbines.
Many years ago we had a batch of new sulfur free fuel and we had many pumps shear due poor lubrication and we had to add a teflon liquid, about a cap full to each wing in a Metro (Flying Tampon) until the refinery fixed the problem.
2008 Pacific CW 2.0 TDI DSG
2012 Landrover D4 Discovery 3.0
Those who get out and and live, and enjoy life's many experiences are wealthy people.
Now that our Eos has reached 10,000Km, I have run my first definitive fuel consumption test for the MY09 TDI & DSG combination. The test was done in a mix of 80% country and 20% town driving with the climate control permanently on.
Distance covered: 842Km
Fuel used: 42.65 litres [Shell diesel]
Fuel Consumption: 17.67 Km/litre, 49.92mpg [Imperial], 41.56mpg [USA]
Who needs a hybrid with their inherent compromises when you can get this economy and performance as well .
Carer for my partner's Eos 2.0 TDI DSG MY09 Candy White/Cornsilk Beige leather trim.
we just did a trip to Wagga Wagga and back via Sydney from Gosford in my mk3 TD. Achieved 5.14l/100km! 2 up with luggage and sound gear for my sisters 21st party. oh yeah, used the air conditioning for 90% of the trip (darned black car)
woot!
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
gldgti,
Not bad!
I just did a round trip Melb Syd Melb on Sat Sun for niece's 21st.
5 adults and boot full of airbeds, sheets, towels and clothing and averaged over the 1,832km 5.19l/100km using aircon all the way and mostly against a horrible headwind on both directions!
Oh and sitting on 2,100rpm for most of the trip on the Hume.
That's about 111km if the gearing suggested in Wheels a couple years ago is correct (53.1 km per 1,000km)
Cheers,
Neil.
BeigeJet
White MY23 Tiguan 147 TDI Elegance (mine)
White MY21 Tiguan 147 TDI Elegance (wife)
Gone - Wheat Beige MY07 Jetta TDI manual
I love weight and balance time, 5% ee100 ashless dispersant at 5% and bob's your uncle. I used to cart the 44 away with the siphon hose running from the back tray into the fuel tank from str8 under the metro wing
Spark ignition is a threatened species
Biodiesel is the best emission control money cant buy
MK1 5 door Mexico Beige 5/79 Golf GLD 1.5
'99 A4 Quattro 1.8T
