Good Question gld,
Here in the land of Oz - no we cant do it our selves, has to be installed by a licenced auto spanner. The vehicle must then be stamped with what amounts to a compliance plate. The cylinder also needs to be inspected every few years - cant remember how often.
I know in England you can fit a full system complete - odd; as I use to think when I lived in UK that England was a "Nanny State".. I am wondering about here now????
The Diesel conversion- depending on the system you use - is actually easier to install than a petrol/LPG system. Because, some of the diesel conversions use just the gas coming off out of the LPG cylinder to inject into the motor - which shows just how little gas these systems use - almost nothing.
Whereas a petrol/LPG uses a large volume of LPG and so needs to heat the liquid LPG to quickly convert it back to a gas.
So this means some of the Diesel conversions have very few parts.
One such typical system is here
A more elaborate conversion using sequential injection system can be found here
It is this system that I would prefer myself; more expensive but has a lot more features, ie; use the brake or off the gas pedal and the LPG is switched off.
Doesn't sound much but it means your gas supply is extended further, making your range even greater. This system also uses LPG at idle; making the idle smoother and transition from standing start better. And there are more features, etc, etc. But this system uses a converter (heater) to heat the liquid LPG.
