Results 1 to 2 of 2
Thread: Got a busted hose, going from fuel pump to the air inlet; what does it to?
    May 2013
    Oslo, Norway
    Got a busted hose, going from fuel pump to the air inlet; what does it to?-aaz-jpg
    Cracked where it fits to the air inlet. There seems to be some oily stuff coming out of it. Car operates normally.
    Edit: Sorry bout typo: "What does it do?" was the question.
    Gosford Central Coast NSW
    It supplies boots pressure to the injector pump which adjusts the fuelling as boost increases.
    If its broken, you will have a small boost leak and no increase in fuelling when you get on boost (less power).
    The AAZ pump has a 'boost pin' which is very mild so you probably wouldn't notice a huge difference.
    A great modification is to take out the AAZ pin and put a 1.6TD pin in there instead. An easy 10hp.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
