On a brand new car it never hurts to make sure the dealer looks into it - however - it seems to be an increasing misconception that all cars are created equal - and some components (if i was going to guess in this case it would be the flywheel) are always made to within acceptable tolerances. How acceptable that tolerance is, is entirely up to the manufacturer - but if VW are making flywheels to within a certain balancing tolerance, and 90% of them are far better than the limit tolerance, doesn't mean there aren't a few cars that are borderline - and probably fine too...
So, if the dealer says "some of them do that" - well its probably true, and most of the time OK, if you don't mind too much.
Vibration is one of the most subjective things you can come across in a car. Some people will overstate it a lot, and others will not even notice the same problem.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
