Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Golf 103 TDI DSG Wagon with body vibration at 1200-1400 RPM
    I received my 103 TDI wagon 2 days ago so I've only put 100 Km on. I notice that there is a little vibration/resonance around the 1500 RPM mark. I can see the image in the rear-vision mirror become a little blurry. But it's only a very small amount of vibration. Once the radio and A/C are on I don't notice it at all.
    That said I'm just a car user, not a mechanic.
    I'll have a look one day to see if the CV heat shields are on.
    Jan 2011
    Quote Originally Posted by interested_party View Post
    Thanks for the reply. Sorry it hasn't been sorted out. Here's an interesting link, from the one you posted earlier:
    http://www.myturbodiesel.com/forum/f...esonance-1907/
    Someone seems to think the CV joint heat shield is the cause on these diesel wagons. When I get mine next week (hopefully) I'll post if mine vibrates and if it has these heat shields.
    Hi,
    Did you get your Golf? If so did you see the same vibration?
    Dec 2010
    Helensburgh
    My Skoda 125TDI has the same issue and I initially thought it was the exhaust resonating but we put it up on a hoist and there are no loose baffles etc in the mufflers and the exhaust heat shields are in good condition. I will put it up again and have a better look at it to see what is what by running it on the hoist and try and locate it that way. I first noticed it when driving slowly looking for a parking spot and it annoyed me and still does.
    Sep 2006
    Have any of the posters with problems had any success resolving this problem yet ?
    Mine goes in to the dealer in the morning ......
    2007 MKV TDI Golf Hatch
    2011 MKVI TDI Golf Wagon
    Sep 2006
    Update !!
    Went in to see the dealer this morning about this issue plus a few other minor things.
    Outcome was that is easy to produce the vibe sometimes but not others. It seems to be an exhaust type drone - like a V6 commodore with a big crap sounding exh.
    General concensus it that it might be doing DPF regen when the vibe is at it worst. The car has only done about 3K, so we will monitor it and have a further look at the 15K service.
    Jan 2011
    Passat TDI also has the resonance
    I recently drove a 2011 build Passat 2.0 TDI (125kW) and it has the same resonance in the 1400 - 1600 RPM range.
    It doesn't appear to be as pronounced - probably because there is more sound proofing in the cabin.
    Also, the engine management system seems to keep the revs above the critical speed before changing to higher gears.
    Dear gds
    Did You find a solution for this issue... my 2012 Golf Variant 2.0 TDI have same problem with resonance from 1200-1400 rpm.
    VW can't/won't help.
    BR
