wow. i have to write this down! i've always been in the habit of clutching in, i think it's because i have this mindset that if i slow down at say 4th gear without clutching in/changing the gears, the car will stall...
yeah i'm still running the car in- it hasn't even done 100! but i'll keep all this in mind when it is run in.
and thanks for that mischa, i didn't know that just revving the engine won't seal my rings- it just seems like everyone refers to it as that. thing is, i can't even get by 3000 without shuddering and thinking the engine's going to die!!! by revving up to about 3000, i can actually use 2nd gear to 55-60km/h! is that what everyone else gets?
MY12 Golf 118 TSI, manual.
Speed in gears depends on the ratios in the gearbox and final drive. As long as your engine is properly warm, revving it to 3,000rpm under load (or even better, 3,500 ) won't do it any harm at all, and in fact will do it a lot of good.
You may just need to get used to the noises a diesel makes if you haven't driven one very much (they are different and noisier than petrol engines).
When cruising on the freeway or highway try to vary your revs between 1800 and 2,500 when running it in (we aren't telling you to drive along with your engine constantly revving at 3,500rpm), with short bursts of hard acceleration to 3,500 when traffic permits (eg after 60Kmh limits, roadworks etc).
yeah i think i just have to get used to the noise it makes and i just have to get over my baby style of driving thanks everyone!
Like those before, I feel that keeping the car in gear is best.
You will end up with a greater particulate buildup if you coast to a stop in neutral, than if you don't and this will cause more soot at take off.
I hope you enjoy it!
omg you are like the king.
hahah i might change my mechanic after what you've said!
i had absolutely no idea about not running the tank down, THANKS! i refuel when the light flashes and i was actually toying with the idea that i should just all the way down to 0, cos that's what i did with my previous car. but now that i know.... geez.
now here's another dumb question from me- please define engine breaking. wiki says that it means clutch down. no one else says this. what i've thought is engine braking is- clutch down, press brakes, slow release clutch.
am i correct?
we really need a forum for manual drivers who have driven auto cars for too long...
ohhhh... so basically I'm have to let the car slow down without pressing on anything. wouldn't it stall!?
yes!!! this is what i do.. so i don't actually know if that's considered engine braking. that's for clarifying that...
Okay now that is too complicated, I'm just going to stick to the basics. hahaha
yes, i've also been riding the clutch! yay! now i know the term... basically I clutch down fully and brake... oh that's bad yeah. okay, this is like learning driving all over
i have to say, i love the boost from the TDi... even though it's a 1.9, it's still heaps more powerful than what i've ever been in!
Thanks mate!
