wow. i have to write this down! i've always been in the habit of clutching in, i think it's because i have this mindset that if i slow down at say 4th gear without clutching in/changing the gears, the car will stall...
yeah i'm still running the car in- it hasn't even done 100!
but i'll keep all this in mind when it is run in.
Originally Posted by
gregozedobe
For slowing down I would be leaving the car in gear with the clutch out, changing down gears as I go. Aim for being in a gear that you could accelerate in if you had to (ie keeping the revs above 1400 or so after you have let the clutch out). Someday this habit may just save your life if you ever need to get out of someone's way.
If I am driving up a steep hill I would be keeping the revs above 2000. Just because a TDI will pull up a steep hill at 1400 or 1600 rpm doesn't mean it is good for the engine to do so.
If driving on the flat or downhill it is acceptable to run at low revs (unless you are still trying to run the engine in).
I am happy to use full throttle on a warm engine and regularly run it up to 3500 right from the very beginning (ie less than 100Km on the odometer), and up to 4000rpm once the car has done 1000Km.
I am firmly of the opinion that the best way to run an engine in is by allowing it to work, but there are many and varied opinions on the best way to run engines in (particularly diesels). Try a search on this and other VW forums and you'll see what I mean.
and thanks for that mischa, i didn't know that just revving the engine won't seal my rings- it just seems like everyone refers to it as that. thing is, i can't even get by 3000 without shuddering and thinking the engine's going to die!!! by revving up to about 3000, i can actually use 2nd gear to 55-60km/h! is that what everyone else gets?
Mischa
simply revving the engine isnt going to seal your rings. you have to use hard acceleration to do so. so accelerate hard to the speed limit whenever you can but try not to go above 3800 revs in the first 1000kms.
MY12 Golf 118 TSI, manual.
