Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Fuel filter case o-ring for MkVI Golf
    Oct 2010
    Melbourne, VIC
    It looks like the right one, though be careful the aftermarket fuel filters can cause the problems, even the Oring doesn't have to be the right size.
    Is this one preferable, then?
    VW TOURAN ENGINE FUEL FILTER O/RING 1K0127434B MANN HUMMEL PU936/1X
    Resident grumpy old fart
    Oct 2010
    Melbourne, VIC
    After discussing the WesFil brand with my mechanic (who services our other car), I got the WesFil WCF130 filter and used the o-ring from that (which was exactly the right size) to replace the split one, wetting it first with the diesel in the filter housing and then torquing up progressively in wheel nut/cylinder head fashion.
    One week later and it's all dry and clean Thanks to all, here.
