Page 13 of 13 FirstFirst ... 3111213
Results 121 to 128 of 128
Thread: ForceFed's Project TDI
  1. #121
    Nov 2007
    Can't help yourself can you? Looks good.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
  2. #122
    Jul 2011
    Quote Originally Posted by ForceFed View Post
    Found a forum member selling a DSG shifter from a GTI cheap cheap and I couldn't resist. Not only does it look the goods it definitely feels a lot more solid compared with standard T-Bar style shifter. Obviously not a straight swap as you would've seen with Adrian13's install.
    Also wrapped my centre console with 3M 1080 Black Carbon wrap. Looks magic.
    Winning! Looks so much better and has the quality feel compared to our T-Bars. Its a shame it isnt a straight swap over! I was so scared to heat and twist that plastic thing holding the lever pin. Did you manage to do it without a worry or? Looks great though nice stuff!
    08 VW MKV Golf TDI - reflex silver | pioneer nav unit | 18" black Apec racing rims | DSG | custom TurboBack exhaust | reset springs | gti steering wheel | R-Line tail lights | angel eye/projector headlamps | gti front | R32 rear | red engine cover | opticoat |
  3. #123
    May 2011
    Unfortunately for me heating the pin was the least of the troubles. What was meant to be a 10 minute job took nearly 2 hours. The trigger pin and locating pin inside the assembly were just floating around which meant the whole trigger assembly had to be taken apart and everything needed to be lined up again. It was like a jig-saw puzzle but got there in the end with help of a friend.
    Anyone thinking about doing this take caution.
    2007 Golf MKV 2.0 TDI DSG
    | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
  4. #124
    Bowral, NSW
    That shifter looks great!!
    The initial DSG shudder and the ridiculous shifter in the Octavia put me right off the DSG option... But loving my manual.
    How hard was it to wrap?
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  5. #125
    May 2011
    Wrapping was quite easy, just time consuming and a little fiddly making the necessary cuts and folds. Took about an hour max.
  6. #126
    Nov 2007
    Now you need to wrap your radio surround, airbag warning insert, ashtray and gear lever surround to match.
  7. #127
    May 2011
    I might have just enough to do the roof lining, the baby seat, the baby, and the accelerator and brake pedals. Lol
  8. #128
    May 2011
    ForceFed's Project TDI-dyno-jpg
    Managed to receive the exact same result over 3 runs. Smoked everyone out on the dyno
