I'll post more pics when I put the 215s on. 235s at this height had some serious scrubbing going on.
2007 Golf MKV 2.0 TDI DSG | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
Yes. They will fit with a little stretch. The 235s weren't stretched. Rim protectors make the wheels look like they are though.
really liking the black and white theme on this car, adding lows always helps a cars presence too![]()
Cheers man. I can't wait to put the new tyres on it and take some fresh pics.
If you're going from 288mm up to 312mm then I agree it's well worth it. It's as you suspect just new carriers required to go to the larger rotor.
I did this exact upgrade on my Caddy workvan and the difference was chalk and cheese, you actually feel confident in being able to stop wthout ploughing into the car in front. I went with DBA slotted rotors and Bendix CT pads with braided lines. Increased stopping power with a noticable reduction in brake dust. My next thing to do when I can fit it in around work is to replace the rears with slotted solid rotors with Bendix CT pads for ****s and giggles and also to reduce the brake dust.
Hi Forcefed
Your car looks very retro and minimalistic with the colour tone. Sorry to have hijacked your thread
They feel amazing compared to the setup I had before. Like I've mentioned I have them set to quite firm until I put the new tyres on. So can't really hammer around corners till the scrubbing issue is sorted.
Thanks again Greg. Will keep you posted.
I'm lovin' this build, congratulations on a great looking car.
I need new headlights, could you tell me the model number of these?
