Page 8 of 13 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 128
Thread: ForceFed's Project TDI
  1. #71
    May 2011
    Huge difference in stopping power. Definitely compliments the tune. I bought it from a forum member. Came with callipers, rotors, pads, and lines.
    Another plus is how nice they look behind the wheels.
    2007 Golf MKV 2.0 TDI DSG
    | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
  2. #72
    Mar 2012
    Quote Originally Posted by ForceFed View Post
    Brakes were toast so Semi-BBK for me...>D
    What a difference with the R32 brakes compared with tiny standard TDI ones.
    Wheels and brakes look great
    Quote Originally Posted by getjet View Post
    They look great mate.
    Have you noticed much difference? Probably a silly question....
    Callipers, rotors, pads... What else did you need to get for the upgrade?
    I gotta' say, i love the white too. I tried to find a white Jetta but no dice...
    That's what I was about to ask too
    Are the standard tdi brakes the same as a gti, I was pretty sure they were?
  3. #73
    May 2011
    I believe they are even smaller than the GTI brakes. I replaced the rears while I was at it with new standard rotors however I switched to ceramic pads.
  4. #74
    Dec 2009
    Melb. (SE), VIC
    I believe that the GT has the same size rotors as the GTI (312mm).
    The rest have slightly smaller (288mm).
  5. #75
    Nov 2007
    Correct. Which explains why he says its such a difference, going from 288mm to 345mm. I'll be fitting my Golf R brakes soon to my GT so will let you know if I feel any difference going from 312mm to 345mm.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
  6. #76
    Dec 2009
    Melb. (SE), VIC
    Quote Originally Posted by poyta View Post
    Interested to know if there's a massive difference too. To be honest, my brakes are crap and will need replacing soon. More so the rears... Was thinking of just going with 312mm rotors on the front and stock rotors on the back. The 312mm front rotors are a direct bolt on with just new carriers (apparently)...
    Are your brakes mk5 r32's or mk6 r's?
  7. #77
    May 2011
    Mine are MKV R32 and yes it has made a huge difference. Standard TDI brakes especially after a tune are ****e. Excellent upgrade.
  8. #78
    Dec 2009
    Melb. (SE), VIC
    LOL, ive already asked how they were. Going from 288 to 345 is a big jump!
    I should have been more specific but i just wanted to clarify if Poyta's brakes were R or R32 brakes? Are they the same?
  9. #79
    May 2011
    His are MKVI R Brakes. They are exactly the same though just different anti-rattle clips and calliper colour.
  10. #80
    Dec 2009
    Melb. (SE), VIC
    Cheers! Whats next on the 'to-do' list Forcefed?
