Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 128
Thread: ForceFed's Project TDI
    May 2011
    Yeah cool. Only problem with 1/4 mile and 0-100 if you break traction readings will not be accurate. It's not like a G-Tech in that respect.
    May 2011
    And now onto a performance/driveability mod. Looky-looky, what do we have here?
    SPRINT BOOSTER
    Before Installation
    What is a Sprint Booster? Well in a nutshell it's a piece of plastic that plugs into your accelerator pedal connector behind the accelerator pedal itself.
    At first I must admit that I was a bit skeptical but I purchased it anyway.
    Yeah, but what does it do? It turns your car into the beast that it should be. It does this by increasing your cars throttle responsiveness by reducing the DriveByWire (DBW) delay, and boy what a good job it does.
    It will NOT make your car faster but it will make it an absolute pleasure to drive. It almost feels like your car has been tuned when it really hasn't. Don't know why Volkswagen wouldn't have the car performing like this straight out of the factory?
    More information can be found here Sprint Booster
    I'm not going to post installation pics because installation is that easy it's a joke. PLUG AND PLAY HARD.
    IMHO, this has been the best bang for buck mod to date. But don't take my word for it. Another member from the "other" Volkswagen forum said:
    Not having a Sprint Booster is like chopping off your right foot. Agreed.
    Another member named it the Evil Black Plastic. Also agree.
    Don't have one? For F*#K sake, buy it, plug it in and enjoy!!!
    After Install
    2007 Golf MKV 2.0 TDI DSG
    | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
    Nov 2007
    sounds interesting.....
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    May 2011
    Now for some wank factor....
    I was intending on going down the APR path with their carbon induction system like so many others have done, however I had completely forgotten that I had a BMC CDA (Carbon Dynamic Airbox) laying around which I had taken out of my Liberty when I first purchased it.
    The BMC CDA is very similar to the modshack in design but has the added bonus of some carbon goodness. Also it's worth twice the price of the modshack and roughly the same price as the APR intake.
    Performance gains? Probably nothing gained however there is an increase in the induction noise and also the wastegate is now more audible. Some people have noticed turbo spooling earlier but I can't really say that I've noticed this at all.
    Street Cred? Definitely looks the part in the engine bay. +++
    Installation? Install was quite straight forward. Obviously the stock airbox had to be completely removed. The only modification you need is to drill a hole for the vacuum hose in between the MAF and intake and stick an irrigation spike into the piece of hose. This unit comes with a mounting bracket, so you will need to find a suitable position to attach it to. I opted to use one of the mount points from where the standard airbox was attached.
    Nov 2007
    Cool, did you manage to get a nice seal between that rubber hose in front of the airbox and the air-inlet in the grille? I seem to recall that Greg had to make something up for that which he did with Carbon Fibre.
    May 2011
    Negative. I just cut the piece of silicon hose to get as close as I could to the inlet in the grille.
    Nov 2010
    nice tidy install. love the description (w**k factor)
    2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
    Jan 2008
    Sunshine Coast
    Yeah, I noticed quite a difference between "as small a gap as possible", and then building a sealed to the outside lid. Massive difference after idling at the lights, which is where I noticed it the most. Seal it to the outside as much as you can mate, but yeah, it's a nice bit of kit!
    May 2011
    Just because......
    Gosford Central Coast NSW
    Quote Originally Posted by ForceFed View Post
    what do you mean? theres no wastegate...
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
