i have the k-14 with the smaller compressor housing, used on a version of the 1.6TD, as opposed to the larger compressor housing one used on the 1.9 TD engines.
the turbo you choose is up to you, but i would go for something on the smaller side since you only wanting low boost and at that capacity, i would say that a small turbo like the k-14 would be ideal - less lag and more than capable to give you the boost well into the high rev range
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
