Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
Thread: Faulty DMF & transmission, yet VGA won't replace clutch
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by jets View Post
    If the DMF was faulty I can't see how it would wear the clutch plate prematurely.
    Personally, I think your expectations are too high thinking VW should pay for a wearing item & not necessary a faulty item.
    I totally agree. The clutch wears when it is not fully engaged and a worn DMF will have no impact on this as the DMF will just move to the loaded position while engagement is increased, with a worn DMF moving more quickly.
    VW have made big mistakes with dealing with some design/production issues but this is not one of them. It seems the dealer has been rather poor at finding the cause of your problem, plus VW don't stock a lot of major components locally, which has increased your level of frustration.
    Do you have to ride the clutch a lot to get the car moving, especially on hill starts? That is a pretty small engine for a Golf Wagon (plus it doesn't seem to have much bottom end torque for a TDi)
    Resident grumpy old fart
