a blanking plate works also
could you explain how it keeps temps down. intuitively i would think it would be putting hot air into the chamber making temps higher?? Nitrogen reduction is understandable of course.
hear hear. the carbon itself isnt a problem as it will flake off as it does in exhausts, but its the oil that catches the soot and makes the sludge coating
oil catchers all the way
TDI mk1 on the road!!
Guys, I'm just rehashing what VW say in the 125kw engine training manual I downloaded from Erwin. Here's the guff:
Task of EGR:
The objective is to reduce nitrogen oxide emissions. This happens because:
1. Less Oxygen is available for combustion due to the recirculated exhaust gas,
2. The combustion speed and therefore increase in temperature are reduced by the exhaust gas that is introduced.
Remember that, in the later diesels at least, the exhaust goes via a cooler first.
But yeah, I too struggle with the idea of going to the trouble of intercooling the charge air, only to add hot exhaust gas post intercooler!
i think its a load of baloney TBH. you put in some exhaust gas to replace the nice oxygen rich charge air that you go to all the work of comrpessing and cooling - so you reduce the efficiency of the cycle as a whole, but your instantaneous nitrous emissions are decreased a bit - whoopy doo.
i cant get over the amount of nonsense that goes on with emission control.
just make the engine as high performing and efficient as possible, then REDUCE the capacity as much as you can!
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
This FAQ mentioned using VAG COM to up the air supply to prevent this problem, because EGR is otherwise important for NOX and temperature control.
http://tdiclub.com/TDIFAQ/
But how do we know VW hasn't already fixed it???
hmmm. i now have DATA about EGT's.
a post in my power quest thread soon boys and girls
'99 A4 Quattro 1.8T
