Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Excessively loud whistle
    Sep 2014
    Unhappy Excessively loud whistle
    Hey guys,
    I'm not new to golfs in fact I've had mine for over a year and have had my romp around in the vwgolf forums.
    I come to you with a really annoying problem.
    So i have the 2.0tdi mk6 standard etc as you would expect.
    It has been tuned to have 103kw and 390nm torque at the wheels.
    While driving through the national park down south a month or so back something happened car kinda freaked out and it developed an excessively loud whistle sound kinda sounds like a vacuum cleaner on high. this happens when accelerating at around 1800rpm to about 3100rpm and it does get really loud, my mate likened it to a supercharger when i drove past his house and he was waiting for me to pick him up. my gf could clearly hear it from inside her golf tdi two lanes over with the windows closed and the music up.
    My mechanic cant figure it out he said he checked over all the hoses and connections etc, hes done a dpf flush so the exhaust is all clear but still the sound is still there.
    if it helps it doesnt do it when the engine is cold, only starts when the engine has warmed up and progressively gets worse. No loss in power though it seems to use more fuel than usual, as i was getting roughly 730ish km to a tank now i get about 550ish...
    Yes i know its not the normal turbo boost sound so don't bother asking this is completely different its kinda like the boost sound on steroids or like a vacuum cleaner on max power.
    Cheers,
    Adam
    QLD
    variable vane control on the turbo?? If the vanes are out of position it whistles loud, the control ring can stick, the actuator can stick (sure mk6 is still vacuum), the actuator can loose vacuum. The VV control is easy to check/test with VCDS.
    just a thought.
    Octavia vRS TDi DSG MY10 - RD Technik tuned
    Polo 9N3 1.9TDi
    Sep 2014
    Quote Originally Posted by harlie View Post
    just a thought.
    Hmm, Is this something that common on the TDI? How would I go about telling my Mechanic to specifically look at this?
    And in the instance where he may have already checked this?
    Note: it doesn't do it while in park or in neutral only under load so when travelling/accelerating.
    Sep 2014
    Awesome, will post findings once everything has been sorted out.
    Gosford Central Coast NSW
    could have thrown a turbine blade, i've seen it happen on tdi turbo's before. If thats the case, it will be out of balance and REALLY noisy as you describe.
    Not saying it IS that, but its a possibility.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Sep 2014
    Only thing is that it only happens once the engine has warmed up. I would think that if it had thrown a blade then the sound will occur constantly.
    I have noticed that when switching off the engine there's a long wind down of the turbo.
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by papa600 View Post
    that would probably be your fans, not the turbo.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
    When the oil is cold, the turbo will spool much slower than when its hot....
    '99 A4 Quattro 1.8T
    Sep 2014
    That makes sense.
    Noticing quite a bit of white smoke now. Getting slightly frustrated with my mechanic as he's not being quite thorough enough, I know something is wrong but he says he's checked all the sensors and there's no odd readings.
    I told him I don't want him checking data I want him going over the engine.
    Next step is taking it to a diesel specialist.
    Or just curl up in a ball and forget the world.
