Good to see an awesome build.
Hope we can get you to some of the events we hold.
2008 VW Polo TDi
GIAC | REMSA | PD160 | DECAT | MUFFLERECTOMY | ECS | SUPERPRO | PXL KIWI WIFI | 312mm BRAKES | OZ RACING | KUMHO V70A
To Buy: VNT 17/22 or K3 Turbo | R783 Nozzles | Intercooler | Water meth kit.
Parts:
PD150 Turbo, Inlet Pipe.
PD150 Manifold with EGR Delete
PD150 Injectors
3 Bar Map Sensor
2008 VW Polo TDi
what are you going to do for the turbo intake pipe? Custom? Or a PD150 cast aliminium one?
I have to run a 36mm Inlet restrictor so will have to make something custom up.
2008 VW Polo TDi
This mornings effort.
Huge discovery is that it looks like the late model PD100s use the same inlet manifold as the PD150. go figure. PD150 on left PD100 on the right. My inlet manifold was pretty clean as well atleast compared to a few others.
Little split in the radiator hose thanks to VW's crappy design, the radiator hoses for the EGR rub.
Turbo Manifold.
2008 VW Polo TDi
Nice work, good to see you in there and messing with the lil beast!
oh nice! I might have to measure mine up, although mine is an early TDI.... Keep up the good work!
Yeah my understanding was that all the PD100's had a dual port manifold with the butterflies but clearly not all of them.
2008 VW Polo TDi
Okay the waiting game for parts has started (will post photos a little later on).
Today's (well yesterday now) progress saw the turbo unbolted, short shifter fitted, engine bay detailed, front of the car detailed.
Went to do the 312mm Brake Upgrade, figuring I would need the hubs off a Polo GTI or similar. Confirmed that I do, so basically if anyone has a set of Polo GTI Hubs or quite possibly Mk4 288mm Disc Hubs I will be happy to take them![]()
2008 VW Polo TDi
